Hi all,
My config : MacBook / Mac OS X 10.5.2 / 5.18 Hercules MK2 driver / Virtual DJ 5.07
My issue is that there is no light activity on all the console buttons. Light is not flashing on the AutoBeat button, no light to know if i'm using Fx/Cue/Loop nor on master tempo button.
Instead of that situation all off these buttons work fine.
Regards
Regards
geposted Sat 22 Mar 08 @ 7:34 am
Hi..oryx
This is the known issue between VDJ 5.07 with the herc mk2. Hope this will be resolved soon with the next version.
U can still use ur mk2 as usual except the led not lit up as normal:)
Cheers.
Cheers.
geposted Sat 22 Mar 08 @ 3:40 pm
Hi SpinnaJ,
Thanks for your answer.
It's under control in dev team's hands so we'll wait for the fix.
Regards.
Regards.
geposted Sat 22 Mar 08 @ 7:42 pm
lucky, ive been stumped with the same problem and thought my console broke. sounds good. peace
geposted Sat 22 Mar 08 @ 10:15 pm
