Why can't my Mac play the wma files????
geposted Sat 22 Mar 08 @ 9:21 am
Apple doesnt natively support these files.
You need to install this , http://qtwmacodec.sourceforge.net/
Then add on Config > Codecs .wma choosing the codec , quick time audio decoder
geposted Sat 22 Mar 08 @ 2:22 pm
I downloaded the software and I added it into the config section, but I still can't play the wm files. pleas help......
Thanks alot
Thanks alot
geposted Sat 22 Mar 08 @ 11:40 pm
Alright , try this codec instead :
http://www.microsoft.com/mac/products/flip4mac.mspx
its a free limited edition but will let you play wma , fine just doesn't allow drm protected files or convering tracks too and from wma.
Microsoft gives no official support for windows media formats on mac any more and only their legacy player is available as abandonware.
geposted Sun 23 Mar 08 @ 9:44 am
Dude.......thanks alot .........its finally playing all of my wma files............is this a trial session? because I don't want it to cut off on me while I have the floor rocking.........lol I have this little gig every Friday nights.............so maybe when one day when I grow I'll be like you.....lol
Skyfx you da man!!!!!!!!!!!!!!!!!!!
your boy Los
your boy Los
geposted Mon 24 Mar 08 @ 4:06 am
Great to hear your up and running , no it wont cut out on you.
You just wont be able to record to wma.
geposted Mon 24 Mar 08 @ 12:22 pm
Huh? I wanted to play my wma files too. However, I can't even see my wma files in my browser. I've done the described steps above, but they stlll are not found in the browser. I even tried to drag-n-drop it into one on my players, no luck. (then I double checked, an mp3 worked)
Anything I'm not doing or doing wrong?
geposted Tue 06 May 08 @ 10:31 pm
Hey! I figured it out! When I went to change the codec list as described above, I kept changing the wmv entry and not the wma because wma DID NOT EXIST in the list! I just didn't look close enough! Duh! :)
They work now! Yahoo! I used the flip4mac software.
Sad to find out it doesn't support DRM though. I guess that means I just have to run Tunebite (the best $25 I've ever spent) before trying to play the wma tracks I download. I have Napster and Tunebite running in a Parallels VM of XP. It just means I can't play that request on-the-fly at a gig as quickly as in the past, I guess. :)
geposted Thu 08 May 08 @ 3:24 pm
I am having this same problem... I downloaded flip4mac and added wma w/quicktime audio decoder to the codecs list in virtual vinyl. The wma files are showing up in the browser, however when I load the song to the deck, I get an error message! Any idea what I can do??
geposted Wed 31 Mar 10 @ 9:25 pm
Anytime I get a WMA file I just use a free program called "Switch" and convert it to mp3 so I don't have to deal with all the bs you guys are going through.
geposted Thu 01 Apr 10 @ 1:17 pm
itunes converts for free, and its already on your mac.
geposted Thu 01 Apr 10 @ 1:42 pm
So should I just give up and convert all my files? How bout re-installing numark and trying flip4mac? Thanks
Raffi
Raffi
geposted Fri 02 Apr 10 @ 5:52 pm
Hello, Help Please...I have done the following instructions from about still no luck with wma files....I can see the files, but when I drag them to a side....it says error????????
geposted Thu 15 Apr 10 @ 4:08 am
djdunneed wrote :
Hey Dude I have the same problem I followed the steps below but it istill not work "ANY BODY CAN HELP?????"
geposted Thu 15 Apr 10 @ 10:07 pm
no se escribir ingles pero esta es la solusion primero bajar ( http://www.microsoft.com/mac/products/flip4mac.mspx ) luego entrar en config
luego en codecs..... en extension le ponen( wma ) y en codec (internal video decoder) y listo a escuchar wma
geposted Thu 22 Apr 10 @ 11:52 pm
geras210: Please do not spam this thread with repeated posts. Please also note that this particular forum language is english; other languages have their own subforums.
Thankyou.
Thankyou.
geposted Fri 23 Apr 10 @ 5:53 am
that foreign guy was right...... thanks very much........... i installed the flip4mac software but it didnt work whe it was set to quicktime decoder in the codec bar...... i then read the foreign guy post and made out few things... change from quicktime to internal video decoder... thanks again
geposted Thu 07 Oct 10 @ 5:52 pm
