hello all
ive searched the forums but have still not fount a solution to my problem
tried the new 2008 drivers today but still have the same problems as before the
auto beat buttons dont light up the sync button on the skins
master tempo buttons turn key lock on and off
there for not being able to lock onto the other deck for synced and locked pitch control
had the same prob with the 2007 drivers on 5.07 aswell
the 4.1 sound card work around worked fine and with the new 2008 drivers it solved the mk2 drop down box problem
but no matter what i try i just cant get it to lock the pitch together
yet useing 5.06 everything all works fine as it should do
im running win xp service pack 2
anybody else got the same problem or is it just me
thanks aubs
thanks aubs
geposted Sat 22 Mar 08 @ 1:50 pm
