Forum: Music discussion
Topic: recording mix a mix tape
please help i want to cut between two tracks eg. track 1 to track 2 without stopping a track (smooth cut)
geposted Sun 23 Mar 08 @ 4:29 am
well i cant remember exactly how to do it but you need to go into recording an select record into multiple files and selecct your folder that way you can get a smooth cut and not have to worry about where the track goes.
does any one out there know? if it is posibble to preview(listen to a new song without audience hearing) using only one sound card if yes how do you do it?
if you only have one output on your sound card then you will not be able to preview. you will need an external device of some kind.
if your sound card is 4.1 or 5.1 then you can assign one of those output to preview.
bro if u really wanna have yur own non-stop then u can edit it or simple is you can use the mixture and u can have yur live recording just connect yur pc to the mixture and do the mixing like djs do in the club
buy a cheap USB soundcard
