Hello everyone !
I'm trying to make a timecoded setup using virtual DJ version 4.3 running on my powerbook G4 laptop which is running Mac Os X and a serato SL-1 soundcard
I've hooked everything up but when i go in the config menu and select " timecodes" in the inputs section i get an error message saying " error in sound driver "
And in the soundcard section i only have numark virtual vinyl i don't have the SL-1 option.
Can anyone help me out ?
Thanks in advance.
Thanks in advance.
geposted Sun 23 Mar 08 @ 2:47 pm
1. Caution using an unofficial copy of the mac version will lead to instability and poor results and the code added by crackers can seriously damage your mac os.
2. Its impossible to use the SL1 box on any other application on mac os due to a lock imposed by Serato , if you want to use VDJ you will need to use a different card.
3. Virtual Vinyl is the only card which works with 4.3 full card support was added in 5.0
If you would like to use VDJ on mac you will need to purchase the application then you will be entitled to free updates , skins and plug ins.
Hope to see you as a pro user soon :)
geposted Sun 23 Mar 08 @ 3:04 pm
Thanks for your quick response :)
geposted Sun 23 Mar 08 @ 3:09 pm
