When i load video some video do not load up. It stays on a loading screen (on my preview screen). I'm new to video. What is the video file, is it mpeg.....?
geposted Tue 25 Mar 08 @ 6:44 pm
click on the file that will not load, and check file info's.
It will list the file format, size and most importantly the video codec used to open the file.
When I have encountered this in the past, It has been due to the fact that the video codec cannot decode the file.
Since it is only one file, and the rest of my files open and play just fine, I usually end up changing the format of that file.
There are lots of file conversion softwares avail for free, When I get home I'll post the link for the one I use. It does a good job.
geposted Tue 25 Mar 08 @ 8:21 pm
thank you, i ll be wait.
anyone esle have any file convertion program that are free. i believe thats my problem. all of my mpeg2 play fine. Just not my Voc or vp6 file.
i will like to convert them all.
What is the best way to do so?
geposted Wed 26 Mar 08 @ 7:34 am
freeware program called
quick media converter.
http://www.download.com/Quick-Media-Converter/3000-2194_4-10787822.html?tag=lst-4
converts using most major formats
geposted Wed 26 Mar 08 @ 8:17 am
