Forum: Greek Forum
Topic: cdj 400
dj foodPRO InfinityMember since 2004
hi xerei kaneis pos tha sinergastoun ta cdj 400 ta kainourgia cd tis pioneer
me to virtual
exoun usb kai sindeonte me ta pc
exete kapoia idea?
thanks
geposted Sun 30 Mar 08 @ 5:07 pm
apo oti mporw na katalabw, i cdiera einai kai midi device kai kapws etsi tha tin vlepei kai to VirtualDJ. Otan dld kaneis plug kai valeis to VirtualDJ na paiksei den tha vlepeis tipota strin othoni tis cdieras, ta lampakia mallon den tha anaboun, alla tha mporeis na patiseis to PLAY kai na paiksei to fortwmeno mp3 sto deck, afou bebaia exeis kanei to analogo midi setup. Twra an kai kata poso to VirtualDJ tha asxolithei me tin sygkekrimeni cdiera ftiaxnwntas ena dll gia native support kai enswmatonwntas to se epomeni version , oudeis kserei , oute kan autoi. Einai allwste poly nwris. Ypomoni.
geposted Mon 31 Mar 08 @ 3:18 pm
primeavPRO InfinityMember since 2008
file sou stelno ayto poy mou apanthsan apo ta kentrika
Date: Tue 01 Apr 08 @ 23:56:18
Teamer: mp3jrick
Message:
That player is midi compliant.
Open config and then remote control.
Right click on General Midi
Click activate
Then Click Config
Here you will assign each of the player's features as you would in keyboard shortcuts by moving the knob, button or fader/slider to sent a note value to the program.
Then click add, move the button or slider and find the appropriate assignment for it.
Click ok after all assignments have been made and you should be set.
Best Regards,
mp3jrick
Virtual DJ Support Team
geposted Wed 02 Apr 08 @ 7:47 pm
