My Setup:
- 2 x Pioneer CDJ 800 MK2
- SynQ SMX-2 Mixer
- Maya44 USB
- VirtualDJ Timecode CD's
- PC with Windows Vista
- VirtualDJ ver. 5.0
My problem:
When I'm using the timecode cd's on my CDJ's, set a cue-point with my CDJ, search through the track and try to go back to the cue point by hitting the CUE button on the CDJ. The software sometimes forgets the cue-point or the track is started but only after a few seconds after hitting the CUE button on the CDJ. Also sometimes the cue-point changes a few seconds back after hitting the CUE button instead of starting from the cue-point I made.
Does anyone have a solution to this problem? Thanks in advance!
- SynQ SMX-2 Mixer
- Maya44 USB
My problem:
geposted Mon 31 Mar 08 @ 5:50 pm
Please register your software and once you do upgrade to v5r7 see if that helps.....
geposted Mon 31 Mar 08 @ 6:11 pm
It doesn't matter which version, I always have this problem. Strange, because I don't have this problem with programs like DJDecks or Mixvibes...
geposted Tue 01 Apr 08 @ 12:17 pm
Nobody who can help me?
geposted Thu 03 Apr 08 @ 11:49 am
