i am only gettign one side of my virtual vinyl to read my timecoded records,i am only seeing one side of the timecode quality reading 100% what to do ????
geposted Tue 01 Apr 08 @ 3:08 pm
What decks n cart r u using. n check whether the rca's not loose. R this only on one side all the time?
geposted Tue 01 Apr 08 @ 10:35 pm
Is it a flat line on the deck with 0% if so i would adise a different cable or cartridge.
geposted Wed 02 Apr 08 @ 6:20 am
i tried interchanging cartrige but ended up with no signal from anyside at all, i am using technics 1210 with ortofon cartridge , i am getting now signal now i tried going back to factory settings pls i have 3 gigs thurs so i need help
geposted Wed 02 Apr 08 @ 12:11 pm
i am getting onside now but the other is giving a wave form but only red while the other is red and green waht next ?????
geposted Wed 02 Apr 08 @ 7:07 pm
If you are only getting 1 wave then your TT is not sending a Stereo signal. Bad channel ? Bad cable from the TT? Bad connection of the cart to the arm ?
geposted Wed 02 Apr 08 @ 8:57 pm
Also did u ground ur TT? n yes check the rca cable from the TT. Maybe its faulty.
geposted Wed 02 Apr 08 @ 10:42 pm
ok i think i got it sort out well one my tt is not sending a signal i thk the cable is bad but i nevr took down a 1200 so i will have to get help thks a lot
geposted Thu 03 Apr 08 @ 10:11 am
