hi all im gonna get virtual dj but i need to buy a laptop first has any one got any reccomendations? i have seen this http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=759407 are the specs ok for running the programme fully also i am purchasing a sound card http://www.echoaudio.com/Products/CardBus/IndigoDJ/index.php what are your thoughts will it all be ok ?many thanks
geposted Fri 04 Apr 08 @ 7:08 am
MSI is a good brand, I sell them and they all work ok, with 2 years of warranty. The sound card is ok but you can't use it on this model as it has Express Card Slot and this Indigo is old PCMCIA slot. All new laptop models has this problem, so pay attention when you make a purchase.
On this model you have a Firewire connection which you can use for sound card input.
geposted Sun 06 Apr 08 @ 10:48 am
i think this model has a pcmcia slot aswell so jopefully it will be ok but ive not made my mind up 100% as it hurts my head looking at all these lptops
geposted Sun 06 Apr 08 @ 11:37 am
can i use my laptop mic for v.dj mic input insteads buying a mixer ? thanks!
geposted Mon 07 Apr 08 @ 2:17 am
