I have a Dell laptop with xp pro and 2.4 duo core pros..2g ram..nvidea 8600 also I'm using VDJ ver. 5.7 and the newmark DMC2 controller
Sometimes there is a delay when I press play on the DMC2 the song starts and a split second after then you hear the beat..so the wave at the top of VDJ and the beat of the song don't match up.
If I close out of VDJ and then restart it, it will fix the problem for a little while.
What do I do about that?
Also I have noticed that if you press the pitch + and - on the DMC2 at the same time by accident the track that you are trying to mix in will then speed up way to fast and then when you press the - button it will slow down way to much.
The only way I have found to fix this is to close out of VDJ and then restart it.
Is there another way to fix this problem?
These are the only problems that I'm having with VDJ but they are happening a lot and it's driving me CrAzY!!!!
Thanks for any and all help with this matter
geposted Fri 04 Apr 08 @ 9:04 am
