I was just wondering what turntables are compatible with virtual DJ
Is my
http://www.amazon.com/exec/obidos/tg/detail/-/B000G3FNVM/ref=ord_cart_shr?%5Fencoding=UTF8&m=A1J7WSBJHTGUFA&v=glance
Compatible, If not can you give me some turnies that are compatible with virtual DJ
Is my
geposted Sat 05 Apr 08 @ 9:14 pm
All turntable can be used with virtual dj, but be sure to get direct drive turntable not the belt driven n a good cart such as the ortofon digitracks. VDJ does not necessary use USB turntable.
The important thing that u must have an at least decent 4 in 4 out (mono) soundcards as its interface between the tt n VDJ. N also to make full use of timecoded, u must purchase VDJ pro legit from this site or alternatively u can get cue pro or virtual vinyl.
Hope to see as a pro user soon;)
geposted Sun 06 Apr 08 @ 1:35 am
Why not get a nice pair of Numark TT500s they are the same to the flagship TTX just minus the digital display which you wont really need if you are using TCV.
A Virtual Vinyl package would be a great sound card , give you a set of vinyls and the full pro software needed for extended time coded use.
geposted Sun 06 Apr 08 @ 6:02 am
Like said above, any turntables work, as long as u have an ASIO. At my work we have it, (im the one who primarily uses it) and i use numark tt200s, just got them recently, and they are very nice
geposted Sun 06 Apr 08 @ 11:42 pm
