Topic: Timecoded CD users: Pitch vs Tempo
idj4uPRO InfinityMember since 2004
Hi all,
Can someone using Timecoded CDs please tell me if VDJ will handle "tempo" adjustment rather than pitch? I always mix with tempo.
I'm planning to use a CDN88 through an appropriate sound card.
I PROMISE i am buying the full version very soon. Decision has been made. ;-)
geposted Tue 21 Dec 04 @ 5:24 pm
apopsisdjPRO InfinitySenior staffMember since 2003
If you're asking about time stretching (or master tempo or whatever..)
you can't have it, by changing the pitch slider in the cd player.
The only way, is to use the "virtual" slider (mouse) or keyboard shortcuts, or an external
cotroller like xp-10 or hercules.
You can use timecode and controllers (or keyboard) at the same time.
geposted Tue 21 Dec 04 @ 6:54 pm
Yes, I want to set VDJ to "tempo/master tempo" etc at the start of the night (so the vocals don't smurf when sped up), but use the CD controller (CDN 88) to beat mix. I only use "tempo" adjust, never normal old pitch when mixing.
I was hoping that with the use of an ASIO sound card, time coded CDs and Virtual DJ combined with a good DJ CD controller and X keys, the only thing I'd use the keyboard for was to search for songs...
Maybe I'll need to look at the XP10s or a mapped DAC instead of time coding afterall....?
geposted Tue 21 Dec 04 @ 7:27 pm
Just checked the terminology in the online manual - yes, I'm talking about Time Stretching. Adjusting the pace of the music without altering the tone.
geposted Tue 21 Dec 04 @ 8:11 pm
djzeroPRO InfinityMember since 2003
it would be a good feature to either enable or diasble this
geposted Wed 22 Dec 04 @ 1:38 am
Ist very great !
geposted Wed 22 Dec 04 @ 6:14 am
claxPRO InfinityMember since 2004
It's already possible do disable / enable TimeStretch. It's in the FAME options.
There's also a skin which allows to do it.
geposted Wed 22 Dec 04 @ 10:59 am
I want to use time stretch, but I want my mixing (controlled via a time coded CD) to be done on a CD player. I know how to turn time stretch on and off. :)
geposted Wed 22 Dec 04 @ 1:43 pm
NAWTBOYPRO InfinityMember since 2003
hey clax......which skin will allow u to change?
geposted Wed 22 Dec 04 @ 3:45 pm
or you can create a shortcut key for this.
I use Alt+M.
But usually (99%...) i dont use time stretching, because i dont like the quality.
If i need to mix a song with more than +- 4% difference, i "rapid" enable Time str..
with Alt+M, mix, and quickly correct the tempo, then Alt+M to disable again.
geposted Wed 22 Dec 04 @ 7:54 pm
Sorry Nawtboy I cannot remember; I just tried all my skins and haven't found. If I can remember I'll tell you.
geposted Thu 23 Dec 04 @ 10:21 am
