i have been using numark tc for the past 8 months and recently its messing up on me.. it used to work perfectly fine and yesterday it started acting up on my... it freezes upon start up and sometimes it doesnt read the controller.... does anyone kno any of these problems??
geposted Fri 18 Apr 08 @ 10:58 am
Hello , what soundcard do you use? which os? what is your spec?
geposted Fri 18 Apr 08 @ 4:30 pm
also are you using the same usb port on your computer that you always have or do you often switch ports? I've noticed some glitching using a different port than I used when I initially installed VDJ, TC and my DJIO.
geposted Sat 19 Apr 08 @ 2:44 am
