As soon as I am playing a music video picture is good for a few seconds, then I get a line on one side of the secondary monitor over top of the video, almost like static, red and blue, then it goes away, comes back, then goes away again. My other computer works flawlessly. There is no problem with the videos, they work fine on the other computer. Suggestions? If I deselect Use Hardware acceleration the problem is magically fixed. Problem is on the DJ screen everything is jerky After that...
Mike
www.winnipegclubentertainment.com
Mike
geposted Fri 18 Apr 08 @ 6:53 pm
Im pretty sure that the PC with the problem has XP, and you are using a "designed for DirectX10" video card. The PC that doestn have problem, if it is with XP it is a card "designed for DirectX9", if not, it is under Vista (Vista has DirectX10).
It thats the case, it has been discused many times. Check around for old threats.
geposted Fri 18 Apr 08 @ 9:26 pm
