Forum: Wishes and new features
Topic: 3 turntables!!!
There is a big gap in the market here. The only pro audio pc software available currently which allows use of 3 decks is djdecks and by the looks of it VirtualDJ is a better product.
I own a firewire card with several ins/outs, sufficient for 3 decks and I think this would be a great addition to VirtualDJ.
geposted Wed 22 Dec 04 @ 9:40 pm
djbambiPRO InfinityMember since 2003
the full version gives you the ability to run several vdj concurrently (even on different PCs) and sync them to one another via network (or localhost). you can output 2 decks of vdj 1 to two outputs of your soundcard, and 2 decks of vdj 2 to two other output... 4 decks. Need to double your system requirements if you're gonna do it on one PC though (say 1Gb RAM).
what firewire soundcard do you have, and how does it perform? I'm possibly in the market for one and would like advice. needs coaxial digital input though...
geposted Thu 23 Dec 04 @ 1:12 am
