Topic: pb avec database
salut j ai un souci avec ma database des fois en tapant le titre d'un artiste il ne me sort pas toutes les chansons et le lendemain ya tout ou alors il ne trouve pas certain artiste alors qu'ils sont le pc
geposted Tue 22 Apr 08 @ 7:29 am
salut
avant toute manipulation fait une sauvegarde de database
dans la config de vdj ==> onglet browser en bas clic sur vérifier => nettoyer => réparer
après dans le browser clic droite sur le dossier qui contient toutes tes mp3 clic ajouter de la base de données
je l ai fait plusieur fois mais le probleme est asser recurent
vdj version5.5
depuis la v5.rev6 ils ont magner database = (don't add folder "$Recycle.Bin" to search database)
pour quoi n'installe tu pas le v 5.07
v 5rev6
sclavel wrote :
Hello,Again, while we are still working on 5.1 (which will be ready soon by the way), we will still release bug fixes on a regular basis as long as we still find bugs (which is getting harder and harder :D).
So here is revision 6, that corrects some bugs and some rare crashes from revision 5.
You can find it in your download center.
Here is the complete change log:
new features
- added support for MP4 video files
- can load and play ambiant video files with no audio
- compatible with ID3 v2.4 tags
- new browser columns "filesize", "filedate"
- optimized for big iTunes library
- new actions "auto_mix_next" and "auto_mix_next_sidelist"
- new pitch ranges 6,8,10,12,15,20,25,33,50% or anything else via registry PitchRange
bug fixes
- freeze in sort thread fixed
- fixed crash when sync_no_cbg before begining of song
- fixed crash automix on some DRM-protected files
- fixed can crash when automixing video sometimes
- improved detect video/karaoke on "add to searchdb" recurse
- fixed preview crash on DRM-protected files
- fixed search in title/artist when filepath/filename not selected
- fixed crash with ID3 unicode comment
- DAC3 fixed
- Denon HC4500 fixed
- "+" in browser for history doesn't show if history is empty
- "move up", "move down" folder context menu doesn't show if topmost/bottommost
- fixed plugins loaded on startup don't show interface
- don't add folder "$Recycle.Bin" to search database
- bug with empty codec list saved as garbage fixed
- bug with thread freeze while closing causing empty codec list fixed
- fixed load mac database on pc and pc on mac.
- fix wrong comments from ID3 tags written by iTunes
- import cover from iTunes tags (.m4a files)
- fix album name from iTunes tags (.m4a files)
- fixed right deck plugin dropdown acting on left deck
parce ce que je flippe grave a passer sur une nouvelle version
tu n'es pas le seul: ça m'arrive regulierement aussi...
si nous toutes les bénévoles nous avons une pensée comme cela on ne serait jamais là à nous entraidées dans ce FORUM OFFICIEL.
c'est ainsi qu'on apprend à résoudre les problèmes !!!
moi j 'evite les probléme c'est mon metier j'ai pas droit à l'erreur !!
moi j 'evite les problème c'est mon metier j'ai pas droit à l'erreur !!
comme on dit l'hereurre est humaine, malheureusement le malheur nous guète de toujours
je connais une veille femme elle a une veille 2 chevaux sa va faire 30 ans qu'elle là
elle dit qu'elle a peur de changer de nouvelle voiture car il sont trop confortable, et leurs nouvelle technologie est trop avancer
elle préfère ça veille 2 chevaux
peut être tu as raison !!!
Lol limol en forme sur ce coup là !!!
@ Richard, je pense que tu peux franchir le cap sans trop de soucis , moi j'ai beaucoup moins de problèmes de database avec la 5.0.7 qu'avant, j'en ai encore parfois du genre certains titres reapparaissent pas analysés , mais sinon rien de bien mechant !!
DJ Julien
