Hi,
I had been working on some issues on tccd setup with spinnaJ on the harware forums, but i guess it has gotten to the point that i should ask the Mac Community for some help.
I have two laptops, a macbook and a dell. I have the MK2 console for pc
i just bought two cdj 100s, and the new behringer ddm 4000 mixer.
I was finally able to get the tccd burned correctly so that the audio signal was not that strong.
On the dell laptop, i am able to get 100% signal strength continously on both cdj decks.
The issue is on the macbook. For some reason, i get continous 100% signal strength on the left cdj, but on the right my signal strength is all over the place.
i checked my cables, they are all new, and as i stated before, on the dell laptop, everything seems to be running fine.
I do have the latest drivers for the pc and mac. and i am running vdj 5.0.7 on both platforms.
i am not running vdj on the mac on bootcamp, it is running natively on os x leopard with all the the updates for the os.
Any ideas are greatly appreciated.
On a side note. the behringer has midi capability, so i bouught the edirol m-1x interface, i was also wondering how do i send midi commands to vdj through the mixer?
thank you for all of your help.
Mindtwister3d
Mindtwister3d
geposted Wed 23 Apr 08 @ 9:54 pm
Could someone with the working CDJ using as timecode here help Mindtwister3d.
This thread is the references to the problem stated. Thanks.
Regards.
Regards.
geposted Thu 24 Apr 08 @ 12:46 am
Just as a side not, i will be testing the ddm 4000 mixer on my dell with a more seasoned dj friend, i will be recording it on my camcorder, so i will post videos, as well as pics.
thanks for all the help.
Mindtwister3d
Mindtwister3d
geposted Thu 24 Apr 08 @ 6:15 pm
fellas, any ideas?
thanks,
Mindtwister3d
thanks,
Mindtwister3d
geposted Sat 03 May 08 @ 3:39 pm
Can u try with other CD players (rackmount or tabletop) n see if it the same?
geposted Sun 04 May 08 @ 11:38 am
Howdy are you using the pro or consumer files for timecode cd?
How does the signal look small or large?
geposted Sun 04 May 08 @ 1:08 pm
Skyfxl:
I have been using the tccd pro, i wll try with the tccd consumer type.
Will let you know as soon as i test it tonight when i get back from work.
Thanks,
Mindtwister3d
Thanks,
Mindtwister3d
geposted Wed 21 May 08 @ 8:41 am
