Hello I have a problem that I had in the past but i cant remember how I solved it.
I use Automix at the moment because bussiness is slow here right now, well I just Formated pc ready for the season ahead & purchased a Dj I/O Sound Card.
Ok Got it working fine till and the end of every ocassional song ( Not All of them ) the cross fader is kicking in and you can hear the next song a lot louder then the one originally playing & when the transition of the two songs have finished the sound level goes normal of that song.
So it goes louder for a split second ( the time of the transition ) making everybody jump.
It happend before on my creative sound card but I think it was the case of changing the sound settings to 5.1 wich i have done with this one but doest work.
I´ve tryed changing all tipes of config, just can seem to get it.
I´m sure it´s something simple just need someone to point this out for a dummy :D
Also would be helpfull if people post how they configure VDJ for automix.
Sorry if this has been posted before but I couldn´t find anything by searching.
my specs:
Mother board : Asus p5w dh deluxe
Ram : 3gb 800mhz
Procesor: Intel Dual Core 6700
HDD: 4 Sata 200gb
VGA: Ati Raedon 1920 Club3d 256mb DDR3
Virtual Dj : 5.07
Thanks beforehand
geposted Fri 25 Apr 08 @ 3:11 pm
If the song is not analyzed or fully loaded onto the deck this will happen.
geposted Fri 25 Apr 08 @ 3:13 pm
The songs have been played before (analyzed) not only that it hapens on the same song time after time.
I also tryed editing entry & exit ponits with no success.
I think it does it when it mix cuts. when it fades it´s fine.
Hope i am making sense.
geposted Fri 25 Apr 08 @ 3:20 pm
