Help my laptop keeps asking for the driver CD for the Hercules MK2, I have re-installed the software but it still ask's for the drivers if I try and lunch the virtual DJ software it say the consol is not detected and starts again.
Thanks Martyn
Thanks Martyn
geposted Fri 25 Apr 08 @ 5:26 pm
i had the same problem , then i noticed that you got to plug the console to the same usb that u used when u configured it , plug always in the same usb , hope this will solve ur problem
geposted Sat 26 Apr 08 @ 3:52 pm
