hi
trying vdj/vv on a macbook pro osx10.5.2
install 5.0.7
numark vv card not recognised...no trace of it in audio control panel, or in vdj. nada.
tried diff usb port.
manual says no drivers are needed, so whats up?
x
Matt
install 5.0.7
x
Matt
geposted Mon 28 Apr 08 @ 8:32 am
Having trouble with mine too. It works but not very good. Are you plugging in the usb before turning computer on? I actually have to plug it in while computer is on rather than off like some say, or it will not recognize it.
geposted Mon 28 Apr 08 @ 12:46 pm
having same type of drama also and it's really pissing me off!!
geposted Mon 28 Apr 08 @ 2:06 pm
matt_black wrote :
hi
install 5.0.7
x
Matt
install 5.0.7
x
Matt
This was resolved at Numark UK Support.
It required a reset of the options.
geposted Mon 28 Apr 08 @ 2:28 pm
This is strange which ports do you use?
geposted Mon 28 Apr 08 @ 2:40 pm
I use the one closest t the power cord. It is kinda weird
geposted Tue 29 Apr 08 @ 3:05 am
Has anyone got the VV working? I stuck everything back in the box and have been waiting to sort the issues out. I will try again and see what happens.
geposted Fri 23 May 08 @ 9:14 pm
