Hi
I recently purchased a Novation nio 2|4 sound card, which has 2 inputs and 4 outputs. What im trying to figure out is how i can cue up a track in virtual dj so that it only plays in the headphones. Can anyone help me please :)
Thankyou
Tom
Thankyou
Tom
geposted Tue 29 Apr 08 @ 7:48 am
i have also had trouble listening to cued tracks using vdj pro. I am using a Hurcules MK2 and cannot split or switch to left or right to listen through my headphones. In Vdj console version all this is fine so why cant i do it in vdj pro?
geposted Sun 22 Jun 08 @ 5:44 am
Select your sound card, select 4.1 mode, choose Headphones and should be ok. The same goes for Tasha, choose "4.1" not MK2 console as a sound card.
geposted Tue 24 Jun 08 @ 3:43 pm
tasha...
http://www.virtualdj.com/forums/91281/PC_Version_Technical_Support/Problem_with_MK2_not_using_channels_correctly_-_Solution.html?highlight=MK2
Sheesh... there are 3-4 threads on this as is it's resolution.
geposted Tue 24 Jun 08 @ 9:33 pm
