Hey guys, new user here! :)
I'm wondering what my options are if I want to mix live and would like to use headphones. Is a 2nd soundcard required for the computer to be able to output a separate sound (for example, from the right deck) to my headphones, while the speakers play the sound from the left deck?
geposted Tue 29 Apr 08 @ 1:25 pm
Yes, if you want two stereo outputs, you will need a second card. You could use a Y splitter, in the meantime.
geposted Tue 29 Apr 08 @ 1:37 pm
What's the difference between those 2 options you just mentioned? What product would you recommend for the Y-splitter? I'm looking for something cheap, nothing professional.
geposted Tue 29 Apr 08 @ 2:03 pm
Try this, then add 2 of these. It does not have to be these, but this is the way you can go. As you can see, there are other options that do the same thing. You can then change the sound card in config, select the headphone option in output. It will be mono, but you will get two separate players, one playing and one you can monitor.
geposted Tue 29 Apr 08 @ 2:28 pm
sorry rick, wonder if this would help... nick take a look at this link it will help you understand one of the options rick gave you for linking up your mixer without a second sound card... http://www.virtualdj.com/blog/tayla/?category=2
geposted Tue 29 Apr 08 @ 3:17 pm
Ah so essentially then VirtualDJ can split the sounds from 2 decks into left and right channel, and the result is mono in my headphones and mono out the speaker (out of each of the 2 connections from the Y-splitter)?
geposted Tue 29 Apr 08 @ 3:21 pm
Two heads are always better than one, thanks for the link.
geposted Tue 29 Apr 08 @ 4:56 pm
hey im a new vdj user and im confused i not able to get sound on my headphones without interferring with the sound going to my speakers. ive bought the y splitter and the audio cables shown in the messege, how many of those do i need. can someone explain to me in detail what i have to do step by step maybe im not using the right stuff that is needed. ive tried everything and cant get it to sound right.
geposted Sat 07 Jun 08 @ 2:16 pm
