Hey, I'm new to all this stuff and Downloaded Demo version.
In config I set output to headphones, but the problem is that I don't know how to get that working. I want to get like with real DJ gear, master from speakers/monitors and the secondary sound (dunno how it's calles) in headphones. What do I have to do to get it work like that?
Thanks in advance.
Thanks in advance.
geposted Thu 01 May 08 @ 11:01 am
What kind of soundcard do you have? Is it a 4.1 or higher? If so you will be able to preview your music using the second set of outputs and assigning them to the headphones. If not you are going to need a second soundcard (like this one http://usb.brando.com.hk/prod_detail.php?prod_id=00091&dept_id=015&cat_id=042) or use a splitter (also known as a "Y" cable).
geposted Thu 01 May 08 @ 11:16 am
