hey everyone,
I'm having a problem with using two sound cards, and I'm hoping someone could help me. I use the Numark Total Control with numark cue. I have the sound config set up as "Output - headphones" and "2 sound cards" selected. The main soundcard plays fine, no problems. The second card, however gives me a little grief. I get a crackling distorted sound, it doesn't last long and it happens every once in a while. any ideas on what that is and how i can get rid of it? Id like to eventually use the "Output - external mixer" setting, but I don't want that sound coming over the sound system...any help would be great!
geposted Fri 02 May 08 @ 2:03 pm
I've noticed this as well. Whichever card I have as the "Second", regardless of role (Main or Headphones), eventually has popping. Both cards play fine when they are "Sound" in the Headphones setup or solo in Single Output.
Any suggested settings to check?
EDIT - I think I got it. Just cranked Latency up (from 256 to 1024) and it seemed to resolve it. I can even keep Master Tempo at Advanced 3/1 it seems. Anything I should be wary of by doing this?
geposted Tue 20 May 08 @ 9:58 pm
Also, re-enabling Safe Mode under Sound Card of the Performances tab seemed to work as well. I just don't like the way key adjust sounds with it enabled though.
geposted Tue 20 May 08 @ 10:18 pm
dj e-rock wrote :
hey everyone,
Which version do you use? If you bought Numark Cue or VDJ, please enter your serial here:
http://www.virtualdj.com/fusers/modifuser.html
to get all the updates and addon's.
geposted Wed 21 May 08 @ 5:24 am
