Topic: Question - Online Broadcasting
hey im thinkin of purchasing the full version of atomixmp3..umm is it easy to hook up your atomix to a website and dj live while having ppl hear you mix? also is there like a step-by-step guide on how to set it up? thanks
posted this here since atomixmp3 forums are dead..
geposted Sun 26 Dec 04 @ 10:43 am
I'm not sure you can open a plug-in directly in Atomixmp3 (maybe new versions I'm not familar about), VDJ has this feature though. But it is possible to open the broadcast plug-in in winamp, where you select SoundCard as output (line-in for external mixer use, or just master output / "what you hear").
It is very simple to set up, all you need is download two free exe files from shoutcast.com, which you install, and than use a plug-in (provided by one of those files) to create sound "packets" live, which are than sent to connected users by server.exe (provided by second one of the files) running in background.
Use the forum search for "broadcast" or "shoutcast" for more info.
erXon
yeh u can, it says it as one of the features
Dj_Vesh
For the technical support of AtomixMP3 please go to www.atomixmp3.com web site
Thanks
i dont no wot u meen erxon because i wont 2 brodcast from my virtual dj aswell but
in my winamp i dont no where 2 go 2, 2 change soundcard as my output
it says i can change my soundcard as my input but that just made me confused
plus on virtual dj wot will i put my adress as and wot will i put my port as
is there anyone out there that can plzzzzz help me
if so add a message on this forum or send me an email at --@--.--
Moderated by Lady Cameron
Sorry djtrader no email address is allowed from a demo user
