I have been using the Virtual DJ Console edition with the new Hercules DJ Console RMX, it works fairly well except for a lack of some features. When selecting preferences I was given the option
trying the 20 day free trial of the pro version, when I selected this, nothing changed on the program. Now when I use the program the play function will not work. every other function works, and the
program recognises that I have pressed play however the track does not start playing, I am thinking this may be because of the 20 day trial being over or something, but I'm not sure. Any ideas
how to fix this would be appreciated.
geposted Mon 05 May 08 @ 10:00 am
Which os u using? Are this on windows platform??
geposted Mon 05 May 08 @ 2:20 pm
I am using Mac OS X 10.5 Leopard on a Macbook if thats any help.
geposted Mon 05 May 08 @ 3:39 pm
hi
i got the RMX Yesterday as well and got the same problem!
mac osx 10.5.3; DJC RMX 1.88 driver
Anyone an idea?
Anyone an idea?
geposted Thu 05 Jun 08 @ 6:48 pm
Check your sound config and select the rmx as your sound card.
geposted Fri 06 Jun 08 @ 7:22 pm
I have the same problem which is the solution? I have cheking sound config and nothing
geposted Tue 08 Jul 08 @ 2:04 pm
Use the USB to the right
geposted Tue 08 Jul 08 @ 9:24 pm
The solution; delete the program. The configuration and preferences files and all the files in library. Install again
geposted Wed 09 Jul 08 @ 6:31 am
