Good evening, My laptop is a 17 inch widescreen with screen display settings at 1680 X 1050. When I attempt to use the this widescreen skin, i receive warning message stating that resolution is higher the resolution.. etc. However, the setting for this widescreen skin are 1280 X 768.
Widescreen setting on my computer 1680 X 1050
VDJ4 Internal Mixer Widescrren 1280 X 768
Why do i receive this message when my setting is greater than the skin?
Thanks,
BigCity1200
Thanks,
BigCity1200
geposted Tue 06 May 08 @ 6:58 pm
Laptops can be a bit twitchy..simply because they can be a couple of pixels under what they claim to be...so it can cause some skin errors..try clicking on the tab between the minimize and close (the maximize tab) and close VDJ and re-open it..does that help??
geposted Tue 06 May 08 @ 7:05 pm
I will give this a try later today and provide results.
Thanks,
bigcity1200
Thanks,
bigcity1200
geposted Wed 07 May 08 @ 1:34 pm
I reloaded the widescreen version and followed your steps above. Appears to be ok now.
geposted Thu 08 May 08 @ 3:49 pm
Glad to hear it...thanks for letting us know..
geposted Thu 08 May 08 @ 3:50 pm
