Dear frieds. I have a computer with two sound cards. I urgently need to know how to configure sound set up to have a main output and prelisten the second deck withut intersecting each other at the same time whilst playing a gig. What is the ideal config for the sound set up fr the followig items: InPUT UTPUT SOUnD CARDS SOUnD CARD SECOnD CARD OUTPUT CHAnnELS. Many thanks.
geposted Thu 08 May 08 @ 11:58 pm
gokyucel
i'm assuming you have an external mixer
go to config > select sound set up >
input - none
outputs - choose either headphones or external mixer
soundcard(s) - two
you now have to select from the two drop down windows which card you want for first and second sound cards
output channels - select which sequence you want either card to be in
Tayla
input - none
soundcard(s) - two
Tayla
geposted Fri 09 May 08 @ 5:27 am
