i love vdj 4.3 and i would really appreciate it if someone can help me and tell me how i can get it to read database created by 5.7.
i was running 5.7 and i had all my music setup nicely with cues and everything but now i went back to 4.3 which i love very much but can't get 4.3 to load the datebase from my external drive. Any help will be appreciated
geposted Mon 12 May 08 @ 4:53 pm
I don't think 4.3 can read up the database directly from the file. If it is possible modification to the file will be needed.
geposted Tue 13 May 08 @ 8:58 am
4.x version can't read from external drive, it has only one database located in VirtualDJ program folder. You can try put it there, but I think that 5.x database is not compatible with older versions of VDJ.
geposted Tue 13 May 08 @ 9:36 am
