Any good turntable that works with virtual dj and mk2 console and the price.
Thank you.
Thank you.
geposted Tue 13 May 08 @ 8:58 am
You can use any turntable on the market, direct drive (without belt) is recommended. Check Numark or Techincs.
geposted Tue 13 May 08 @ 9:48 am
Numark TT 500s would be perfect for this they give good results as they use our flagship ttx motors giving a good torq and responsiveness at a lower cost as it does not have the digital displays.
geposted Tue 13 May 08 @ 4:51 pm
Numark tt200s are great too, but obviously tt500 are better, but the 200 are nice. Numarks look awesome with Virtualdj vinyl btw
geposted Tue 13 May 08 @ 8:21 pm
I also recommend the 500's. I used to use them & for the price they can't be beat. 5 kg of torque & a ton of features, they even include both s shaped and straight tonearms so you'll have whatevers right for your mixing style. Only drawback is you have to get carts seperate. I'm using cd decks now (stanton c.314's), but if I had to go back to turntables I'd buy another pair of 500's in heart beat;^]
geposted Wed 14 May 08 @ 4:24 am
A lot of thanks to all
geposted Wed 14 May 08 @ 8:30 am
Also try to look at stantons too. They do make decent direct drive TT.
geposted Wed 14 May 08 @ 4:58 pm
