hello, i have been using the vdj software are and the hercules console for some time. this is my problem. i plan on taking an extended trip to central america plan to and pick up dj gigs along the way. the problem is space. i need something a bit smaller then the hercules. all i need to do is be able to preview tracks before i play them and then mix them im with the software.
i have a 2 open usb ports and a firewire port and a pcmcia slot.
any reccomendations?
thanks!
thanks!
geposted Wed 14 May 08 @ 12:04 am
Smaller than MK2? Damn!
You can use some external Sound card but it will be easier with MK2 as you have all you need in the small package ;)
geposted Sun 18 May 08 @ 9:58 am
