hello im having a problem with my soundcard not working
i was using verison 3.4 for the longest time... because it worked
well for me i just udated to the new verison 5.0.7 and got a total control
well my sound card isnt working now and i have tried everything.
im using a mark of the unicorn mk2 firewire and i have a sony viao
2.0 intel core 2 duo 800fsb 4m cache/ 2bg of ram/ nvividia 7800 256mb
thanks for the help i had to go back to old verision and everything works fine
except i cant use the total control
geposted Wed 21 May 08 @ 11:28 am
Did you tried newer drivers for your sound card? Also you might need to update DirectX.
geposted Wed 21 May 08 @ 11:49 am
i will give that a try thank you
geposted Wed 21 May 08 @ 12:08 pm
