Hey, I'm looking to do a clean install.
Basically i want to remove all existance of VDJ from my computer. I assume the uninstaller will do this but let me know if some manual stuff needs doing also.
However i've spent ages Analyzing my music to the correct BMP so ideally i want to restore that on the re-install. Pretty sure all the other settings can go.
So baiscally i'm asking what file(s) it is in need to backup and reinstate once i've re-installed VDJ.
Cheers.
Cheers.
geposted Thu 29 May 08 @ 7:57 pm
Help! I really need to do this ASAP.
Am i right in thinking...
1. All i need to backup is the "VirtualDJ Database v5.xml" file
2. The only places VDJ installs itself are..
C:Documents and SettingsxxxxMy DocumentsVirtualDJ
C:Program FilesVirtualDJ
And the registry also?
Assuming the unistaller will do the reg and everthing but the extra plugins and skins i'm using right? No issues with the licence not removing I hope?
geposted Fri 30 May 08 @ 7:20 am
Will the registry automatically be removed on an un-install?
I want all the settings gone.
geposted Fri 30 May 08 @ 7:38 am
Anyone? I wanna do this tonight if possible.
geposted Fri 30 May 08 @ 2:27 pm
Go download the Registry tool from the plug-in external tools section. This has a registry cleaner component.
geposted Fri 30 May 08 @ 2:30 pm
Are we talking the "VirtualDJ Registry Key Removal" if so it says "Atomix Productions can't be responsible for the any problems that are due to the use of this application and gives no support for it." which sounds a little worrying, is it ok?
http://www.virtualdj.com/addons/view.html?type=tool&page=3
2nd one down.
Or was it the "Registry Tool v1.7"?
http://www.virtualdj.com/addons/view.html?type=tool&page=1
2nd one down.
2nd one down.
2nd one down.
geposted Fri 30 May 08 @ 2:54 pm
This one,
; and you would go past the first page to see if there was another - lol?
2nd one down.
2nd one down.
geposted Fri 30 May 08 @ 3:14 pm
Just go to:
Run>Regedit>Current User>Software>VirtualDJ and delete the whole folder key.
geposted Fri 30 May 08 @ 7:22 pm
DJ-ALF wrote :
Just go to:
There is more than just that one key.
geposted Sat 31 May 08 @ 2:46 am
DJ-ALF wrote :
Just go to:
I know, but I can't explain all of them now ;) I am busy chasing Torrents :)
LVL MOD
geposted Sat 31 May 08 @ 7:59 am
