ok first off i am currently using serato at the club but heard good things about your product and wanted to give it a test drive! I have had many issues but thought I had them all figured out until now. Seemed to be working fine finally removed the static sound by reading up and finding out my ground wires werent grounded properly and everything was working good until i loaded up videos! seems my graphics card and my firewire soundcard are causing conflicts. They are both on IRQ 16 how can i fix this? I have read the sticky that skyfxl put up but seems in vista I am not able to uncheck the auto assign
geposted Thu 29 May 08 @ 9:28 pm
as you can see IRQ 16 has every damn thing on it! My video card and IEEE 1394 Fire wire which i think is causing the problem. It works fine for a while then all the sudden the static and bad sounds starts up.
IRQ 0 System timer OK
IRQ 1 Standard PS/2 Keyboard OK
IRQ 8 System CMOS/real time clock OK
IRQ 10 Intel(R) ICH8 Family SMBus Controller - 283E OK
IRQ 12 Synaptics PS/2 Port TouchPad OK
IRQ 13 Numeric data processor OK
IRQ 14 ATA Channel 0 OK
IRQ 15 ATA Channel 1 OK
IRQ 16 Mobile Intel(R) PM965/GM965/GL960 Express PCI Express Root Port - 2A01 OK
IRQ 16 NVIDIA GeForce 8800M GTS OK
IRQ 16 Intel(R) ICH8 Family USB Universal Host Controller - 2834 OK
IRQ 16 Intel(R) ICH8 Family PCI Express Root Port 1 - 283F OK
IRQ 16 Intel(R) ICH8 Family PCI Express Root Port 5 - 2847 OK
IRQ 16 AGERE OHCI Compliant IEEE 1394 Host Controller OK
IRQ 17 Intel(R) ICH8 Family PCI Express Root Port 2 - 2841 OK
IRQ 17 Silicon Image SiI 3531 SATA Controller OK
IRQ 18 Intel(R) ICH8 Family USB2 Enhanced Host Controller - 283A OK
IRQ 18 Intel(R) ICH8 Family PCI Express Root Port 3 - 2843 OK
IRQ 18 Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.0) OK
IRQ 18 Intel(R) ICH8 Family USB Universal Host Controller - 2832 OK
IRQ 18 Intel(R) ICH8M 3 port Serial ATA Storage Controller - 2828 OK
IRQ 19 Intel(R) ICH8 Family PCI Express Root Port 4 - 2845 OK
IRQ 19 Intel(R) ICH8 Family USB Universal Host Controller - 2831 OK
IRQ 21 Intel(R) ICH8 Family USB Universal Host Controller - 2835 OK
IRQ 22 High Definition Audio Controller OK
IRQ 23 Intel(R) ICH8 Family USB Universal Host Controller - 2830 OK
IRQ 23 Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836 OK
I
I
geposted Thu 29 May 08 @ 11:35 pm
can you turn off the firewire , even temporarily ?
other possibles ..... turn off wifi and bluetooth .....
pop out the battery , turn all power mgmt settings to never
if safely do able turn off anti virus
geposted Fri 30 May 08 @ 8:34 am
I keep the wifi, anti virus off when I was testing this
if i turn off firewire i wouldnt be able to use my soundcard! you think dissableing it and reinabbling it might switch IRQ?
Power mgmt is set to never
Like I said it works great with video and I am able to scratch and all but after a while it just starts to turn to static sound and the only
thing i can figure out is it has to have something to do with the Video Card and Soundcard sharing the same IRQ!
Skyfxl can you help by any chance? I read your tutorial on how to change IRQ but where the option is to uncheck the box of auto sign
IRQ it is shadded and not accessible. I am using Vista by the way. I really like the program but seems like it is alot of trouble people have to
go thru to get it to work. Its the only downside compared to Serato....
My demo runs out this Sunday please help
geposted Fri 30 May 08 @ 10:15 am
i didn't know if your card was firewire 'til you said so ......mine is also
you might need to contact serato
was your antivirus on during the install ? you might just need to turn it off and reinstall
i'm gonna see what i can find about changing irq's in Vista .....
geposted Sat 31 May 08 @ 7:48 pm
I couldnt figure out how to change IRQ's in vista but could find the drivers if I wanted to use Windows XP if that would make changing the IRQ easier? What is weird I was watching the latency tester and everything seems fine until I throw on a video so it makes me think that with both the soundcard and videocard working at the same time its too much being on the same IRQ. If I am not mistaking seems my USB ports which I have my external harddrive on is on this IRQ as well so everything is running thru this.
geposted Tue 10 Jun 08 @ 2:03 pm
