Hi Everyone.
I am really busy at the moment scanning my Mp3 Collection using Mixed In Key. My question is this. When i run virtual DJ and I load up the directory of my recently scanned files it does not show the info in the ID3 Tags. everything under the artist section also shows the song title so i am having to input the data myself. Why is this? I am creating a huge amount of work for myself :( I also used used exact audio copy to rip the files to 320kbps i hope this is ok. If i change the details of the tags in virtual DJ when i have finished can i copy the XML file or whatever it is onto my Laptop so that the changes Made on PC will show up on Laptop.
Thanks
Thanks
geposted Fri 30 May 08 @ 7:36 am
mmm no replies..... ok here is another question. I'm using latest version of Virtual DJ how does one get to show the key that Mixed In key has provided into Virtual DJ Which Skin? on clicking file infos the key is there but bot showing on the skin. I have also put a tick in the drop down box at the end of the search bar but no joy :( can anyone help... many thanks
geposted Fri 30 May 08 @ 12:18 pm
Currently there is not a Key code for using in the skin designs. But there are some small skinning improvements planned for the next release and that is one.
The tick for the drop-down box, just means you can use the Key field for search so if you want to see all the Am tracks it will search the key field for that string.
And, as always my standard disclaimer for everyone else - please don't ask when it will release as I know those question threads have already started a couple times.
geposted Fri 30 May 08 @ 2:03 pm
