I need help and I need it fast,
I am a vocalist who's just discovered VDJ and it's streaming possibillities, but I have run into some problem.
I have an external soundcard that I use for my microphone, it's a M-AUDIO FIREWIRE 410 soundcard, and they have no built in mixer
so in ordr to mix my vocals I need to use software.
Ok so my question is this, has anyone any idea on how to mix vocals in VDJ. or can you recomend any other software that I can use for this.
I still wish to use VDJ for streaming though.
Give me tips on what to use and how to use it please..
oh and did I mention I need it fast? like in 2 days time? might have to cancel a show otherwise.. =_=
Thank you!
/Nena
Thank you!
/Nena
geposted Fri 30 May 08 @ 8:40 am
This is not the right solution for what you are trying to do. You need to look into software more appropriate for what you are trying to do. VirtualDJ is a DJ tool.
geposted Fri 30 May 08 @ 8:55 am
Isnt it like a voice over she is trying to do? Why wouldnt a dj be alble to voice over? Seems that was her question.
geposted Sun 01 Jun 08 @ 3:56 pm
Yes and no, vocalists rely on a very clear sound signal to higher standards than just speaking. True VDJ does have a mic option for broadcasting/recording but it is intended for introducing songs and such. If she truly wants to record or broadcast her voice it is not the best option. I would suggest looking into a podcasting set up with a high grade sound board and mic...
geposted Sun 01 Jun 08 @ 4:15 pm
