Hi!
At first sorry for my bad english!
I have the Virtual Vinyl Hardware/Software solution including turntables, mixer and laptop.
My problem is that I want to record my mix (record from master) . But I want to avoid that I hear the noices that it makes in the channel which is faded off. In other words: The fader of software don't move when I move the fader of my real mixer. Do I have to change something in settings or something of my mixer? Is there any possibility or do I have to buy me a mic?
Hope you can help me.
Bernd
Bernd
geposted Fri 30 May 08 @ 5:13 pm
Please register your software in your profile , so you can get the latest update.
Go to config > options and disable the crossfader if you want to use a real mixer you will need to take a line in back into the laptop and choose line in as the recording option.
geposted Fri 30 May 08 @ 5:42 pm
