Hello,
I just bought a Numark CM 200 USB mixer board and I use Virtual DJ software.
When I use the mixing switch on the board, there is no feed back of the changes on the GUI of Virtual DJ.
Is there a fix to this ?
Best regards
Y.
Best regards
Y.
geposted Sat 31 May 08 @ 1:13 pm
Hi it is not a midi mixer so will not control the software directly.
It is a dual usb sound card which will allow you to mix the output of the software decks externally as if they where an external source such as a cd player.
geposted Sat 31 May 08 @ 4:56 pm
