Hi Everyone.
First of all many thanks to the virtual DJ Staff for the release of 5.1 :). What i want to do is this, i currently have 5.1 on my home computer for which i do not use to play at my venues i only have this to edit my files and then transfer them to external hard drive am i allowed to have 2 installations? my second question is? if i copy over the XML File in Virtual DJ to my laptop will all the editing that i have done be in that file or will i have to start from scratch. i think it is the Database file. if someone can confirm what i need to do that would be great.
geposted Mon 02 Jun 08 @ 7:39 am
Yes, you can install VDJ on 2 machines. And second is correct, xml file holds all your information, just copy on your laptop and you will have all your info there.
geposted Mon 02 Jun 08 @ 11:04 am
thanks for your reply
geposted Mon 02 Jun 08 @ 11:12 am
