Hey guys,
I am considering purchasing Virtual DJ but had questions about connecting the laptop to the mixer. The Denon mixer I have now is about 5 years old and needed to know if it was compatible or can be made to be compatible? Is there a list of supported mixers? What kind of an input does the mixer need to connect the laptop with Virtual DJ to it? What kind of cable will I need?
thanks for you help with this!
Kevin
Kevin
geposted Mon 02 Jun 08 @ 1:50 pm
You'll need a sound card that suffices your needs. As long as you have a sound card any mixer will work. Spend a week on these forums looking through threads and 99% of your questions will be answered. There are a few mixer/sound card options out there but only a few so your mixer won't work. Most (external) sound cards are usb and there are some firewire ones.
geposted Mon 02 Jun 08 @ 7:20 pm
use the search box on this forum will help you a lot for what your looking for ie:- mixers, sound cards etc... hope that helps
Tayla
Tayla
geposted Mon 02 Jun 08 @ 7:41 pm
Great. I was told by a friend who mentioned Virtual DJ to me that I would need a mixer with a midi input and that my mixer was incompatible. Let me make sure I have this right. I can use the sound card built into the laptop and plug the rca cables right into my mixer? that would be great.
Thanks alot!
Kevin
Thanks alot!
Kevin
geposted Tue 03 Jun 08 @ 7:24 am
try this mate, it may help you http://www.virtualdj.com/blog/tayla/
geposted Tue 03 Jun 08 @ 7:29 am
Thanks for the info! I'll give this a try at home tonight!
Kevin
Kevin
geposted Tue 03 Jun 08 @ 7:46 am
