I just received my VestaxVCM 100. It's working well with traktor 3LE.I am hoping there is a mapper coming soon for this controller. Can anybody help me? I will post in Hardware tech support. Thanks.
geposted Mon 02 Jun 08 @ 2:30 pm
Download the latest 5.1 version its fully supported in that.
geposted Mon 02 Jun 08 @ 2:36 pm
The VCM is not supported in 5.1, but the VCI-100 is.
You can use the VCM with VDJ now using the general midi mapper (a very good feature in VDJ), you can easily map any midi controller, the only downside is that the lights can't be programmed, you must wait for native support before the lights will work fully.
geposted Mon 02 Jun 08 @ 3:30 pm
Thank you for the info. I've been working on it for a while and everything seems to be falling into place ( so far).I am very happy with the unit.I have the pitch controls working properly and sync buttons, loops ,eq,etc.I don't do any scratching.Just a couple of issues. Can't get the headphone out to play without coming out of the mains.Will work on it tomorrow(or today). Thanks again.
geposted Tue 03 Jun 08 @ 1:41 am
Well dhe8dave was right .The VCM 100 is supported in 5.1. I spent an hour or so programing the VCM 100 general midi to my liking. But this morning I DL 5.1 and just to see what would light up on the controller when I config the VC 100 , everything worked on the VCM 100. I am getting sound out of the monitor outs but not the mains. Will trouble shoot. Thanks guys. This is working out great.
geposted Tue 03 Jun 08 @ 11:14 am
Read my post, every midi controller is supported, but not all are natively. The VCM-100 was supported before the update, just as the VCI-100 was, but the difference is that the VCI-100 is now supported natively.
geposted Tue 03 Jun 08 @ 3:31 pm
new to the site. I did have question on the VCI 100 but its been answered. Gracias.
geposted Wed 04 Jun 08 @ 7:15 am
