i need some help buying external devices... i dont want to buy something and it wont work at the end..... i was lookin at denon dn-s3000, dn-s1000, numark tt220 (turntable), numark ttx.... thats just some stuff i was looking at... again i need something that is not as costly but works well... no problems what so ever.. so please help me im open for any suggestions
geposted Tue 03 Jun 08 @ 10:04 pm
those all will work.. as for problems.well,i havent owned non of these to try.However i do own two other sets of denon cdj's that work flawless 99.9% of the time.
keep in mind you will need a 4 in/4out soundcard to hook cdj/tt to cpu.
as for style you might wanna tr your local dj store .they should have most brands hooked up to try before you buy.
also with turntables,only certain cartriges are recommended so u might wanna search on that.
hope i've been helpful.
good luck on finding what suits your needs/budget
geposted Wed 04 Jun 08 @ 9:44 am
