Tried this on three laptops all direct x updated and the software freezes. I have had it running earlier today for the first time and now it fails. Any idea why?
geposted Wed 04 Jun 08 @ 11:23 am
Karaoke plug-in? I assume you mean one of those that do it's best to cut vocals? Link to the plug-in would be helpful
geposted Thu 05 Jun 08 @ 12:35 am
@CHOPSTIX
I think he's talking about the karaoke plugin (found in visual effects) that is included since 5.0.7.
@Chris
Look in your VirtualDJ folder under My Documents and open Crashguard.txt file, then post the content here.
@Chris
geposted Thu 05 Jun 08 @ 3:37 pm
No crash report as it just freezes, Vista message is that the VDJ has stop responding asking if i want to wait or close. Had the same problem on two other laptops. Tried the plug in with PCVJ with similar issues but once i resorted the software back to factory settings on PCDJ it worked but takes PCDJ a long time to close after play. I will keep testing and try and find how best to work around.
geposted Fri 06 Jun 08 @ 5:51 am
I use XP Pro, so my tests would not help you. I hope you get it sorted out, good luck :)
geposted Fri 06 Jun 08 @ 7:24 am
Finally found the report fFreeze (date=806041523, version=5.1 Pro, build=510, thread=Video)
Freeze (date=806041524, version=5.1 Pro, build=510, thread=Video)
Freeze (date=806041541, version=5.1 Pro, build=510, thread=Video)
Freeze (date=806041556, version=5.1 Pro, build=510, thread=Video)
Freeze (date=806041558, version=5.1 Pro, build=510, thread=Video)
Freeze (date=806041626, version=5.1 Pro, build=510, thread=Video)
Freeze (date=806041720, version=5.1 Pro, build=510, thread=Video)
or the freeze
or the freeze
geposted Fri 06 Jun 08 @ 8:03 am
