The problem is once you selected then activated the video effects the window pops up to show u it like shud do. The bug is that you de-activated the effect and the window still is there, I close the window and pressed minmize on vdj and the video window pops up again.
I can keep pressing the close button on the video screen window and it keeps popping up even tho the effect is de-activated. I've checked the video option in the configuration window and it say that the video is still activated even tho I de-activated it tho the effects window, once I deselect the activation from the config window and as long as I dont re-activate the video effect the video screem window stayed closed.
Hope that helps, Great work on the new Vdj by the way! just tryin to get use to the new engine
geposted Thu 05 Jun 08 @ 8:47 am
First if you are using 5.1 you are using a crack version. We have not released a demo of this version.
If you are a licensed user - please update your profile.
Second, the video window always stays open and visible when the video module is Activated.
geposted Thu 05 Jun 08 @ 9:08 am
