Whats the lowest version of VDJ that the Hercules RMX is compatible with?
geposted Fri 06 Jun 08 @ 2:12 pm
Hi, not sure what u really mean.. lowest version of VDJ??
It should be the one that came with it as a gift..the VDJ LE version;)
geposted Fri 06 Jun 08 @ 2:27 pm
in other words, can it work with the full 4.3 for the Mac. or would you need to upgrade to 5.0.8
Ignoring the free LE version it comes with.
geposted Fri 06 Jun 08 @ 2:37 pm
Nope.. u need the latest pro version for it to work properly.
Do register ur LE serial in the modify ur profile n dun forget u could have special discount too when u upgrade to pro:)
Hope to see u with us soon.
geposted Fri 06 Jun 08 @ 2:42 pm
ok. and how much does it cost to go from LE to pro?
geposted Fri 06 Jun 08 @ 2:45 pm
geposted Fri 06 Jun 08 @ 2:47 pm
