Hey everyone, could some one quickly let me know how to print out my kj list I've forgot and secondly, haven’t used my kj in a while and when I click on my kj folder its taking forever to load and stopping vdj from playing other music. I know vdj works fine for me and has worked my kj before but I just put it on a new drive and its really killing everything, what can I do to get it to load faster, and do I have to add each folder by it self to the data base or can I just right click the main kj folder and hit add to data base?
geposted Sat 07 Jun 08 @ 12:14 pm
you may have to re analyse your music again, as for karaoke lists i use an external compiler there's quite a few out there so just put in google and you will have quite a selection to choose from
geposted Sat 07 Jun 08 @ 12:20 pm
I use a program called mp3tag which i can batch tag folders, it also has a function to export the all the folders to a csv file so i can print out all my songs in different genres. ie: house, RnB, classics (70 & 80s) & Dance (techno)
Kaoz
geposted Sun 08 Jun 08 @ 3:17 am
mp3tag +1
geposted Mon 09 Jun 08 @ 7:20 pm
i just use my pcdj to ripp all my music and use pcdjgroups to create my playlist. my virtual dj is used for all my gigs
geposted Mon 09 Jun 08 @ 8:20 pm
I think it's time VDJ incorporated a print feature, both for playlists and history, just a right click option to print would be fine, and just listing the tracks as <artists> - <title> would be perfectly adequate for most users. It's definitely on my wish list.
geposted Tue 10 Jun 08 @ 8:47 am
I over came this problem by querying the xml data base stored in the VDJ folder using excel - then used excel to filter and print.
You cant open the database in excel if VDJ is active (open)
geposted Mon 07 Jul 08 @ 11:09 am
