can you add features to skins that you download
geposted Sat 07 Jun 08 @ 2:55 pm
not sure on that but you can manipulate the original to suit your needs...
geposted Sat 07 Jun 08 @ 7:03 pm
yes, you can edit the files.
the bmp file and the xml file.
with the new features and upgrade of 5.1, we'll have to.
open "my documents' \ virutal dj \ skins \ name-of-skin.zip
there you will find 2 files, a bmp file: graphics ; and an xml file: code
together these two files create a skin.
you can create crazy stuff with the skin if you know how.
geposted Sat 07 Jun 08 @ 8:29 pm
