I currently use a PCDJ DAC3 controller with Cue. However, I can't get the Mix Now button to work. Any ideas? I have the latest .DLL download.
geposted Sun 08 Jun 08 @ 10:40 pm
The current DAC-3 mapper was designed for VDJ 4.x - Due to changes made to later versions of VDJ (Such as the single-deck automix), some functions such as MIX NOW don't work anymore.
There is an update for VDJ 5.x currently in progress, which will fix this issue and a number of others. This will be released once time allows for it to be completed (After updates currently in progress for the Denon HC4500 and Numark DMC-2 mappers have been completed and released.)
geposted Mon 09 Jun 08 @ 1:28 pm
The DAC 3 mix now button will mix now off the side list.
geposted Fri 13 Jun 08 @ 3:29 pm
