Ok, I am a newbie when it comes to VDJ.
Would this setup work?
usb turn table, plugged into my laptop running vdj, and have the 2 tables plugged into my mixer and the mixer into my amp.
YES? NO?
if no what part of the chain am i missing? HELP!!1
YES? NO?
geposted Mon 09 Jun 08 @ 2:37 am
You need a sound card with at least two stereo channels (left and right), that has not only outputs, but INputs, so that the timecode on the turntables activate control of the audio, within VDJ. Does your mixer have that built in?
geposted Tue 10 Jun 08 @ 3:28 am
I am planning on using a NUMARK DXM01USB
yes?
yes?
geposted Tue 10 Jun 08 @ 4:09 am
There's no point in having a usb turntable unless it's a midi turntable. The only real way is with a timecode solution through a sound card.
Yes that mixer will work:
http://www.virtualdj.com/products/hardware.html
geposted Wed 11 Jun 08 @ 12:44 am
